Squeaking Passenger Window - Help!
Old Feb 8, 2011 | 09:38 AM
19962door's Avatar
Smile Squeaking Passenger Window - Help!
The passenger window squeaks each time it leaves the rubber molding at the top.
I tried WD-40, no good. On another forum, it was suggested a silicone spray/dry lube spray might work. I bought Liquid Wrench Dry Lubricant, again no help.
Would Permatex silicone spray be the magic cure? I can tell you the window is slightly loose. i.e. at certain spots in the track there is a slight rattle.
What's interesting is the driver side window, which had to be replaced when the window was smashed several years ago - the nitwit took quarters from the change draw - works fine, and doesn't rattle.
Thanks,
Robert
Old Feb 8, 2011 | 10:11 AM
Although a little pricey, what Honda uses and works well is Shin-Etsu grease.
handa-accessories.com/accmaint00.html
But, a silicone grease or spray should work, it just may not last as long as the Shin-Etsu grease.
Old Feb 8, 2011 | 04:23 PM
19962door's Avatar
Where should the grease or spray be applied? Is it applied to the window track, or does it get applied to a part(s) within the door?
Old Feb 8, 2011 | 07:03 PM
There a rubber channel runs that should be cleaned and then silicone or Shin-Etsu grease applied. It is best to remove the door panel and then clean the channel runs with something like q-tips and rubbing alcohol and then apply the silicone or grease.
Attached Thumbnails Squeaking Passenger Window - Help!-glass-channel-runs.jpg
chumperdink
May 1, 2012 04:59 PM
erivkin10
Sep 28, 2008 02:00 AM
Planefreak
Oct 17, 2007 02:28 PM
19962door
Jul 20, 2007 08:47 AM
