Window or Door Squeaking
Old Sep 26, 2008 | 04:05 PM
erivkin10's Avatar
Default Window or Door Squeaking
I purchased my '06 EX-L 8 months ago with about 30k miles on it. It now has 35k miles. Lately the doors or windows have been squeaking. It is the best term that comes to mind. It sounds like the door glass or doors themselves are shifting slightly in place against the window or door rubber when riding over irregular pavement or bumps. Sometimes the sounds comes from one door; sometimes several. I have been unable to find a pattern to this but it is very aggravating when they squeak.
Any thoughts or suggestions are more than welcome.
Thanks for reading the post.
Old Sep 26, 2008 | 05:36 PM
falkore24's Avatar
Default RE: Window or Door Squeaking
First, I'd clean out the tracks with Q-tips, cotton ***** and alcohol. Then spray them with silicone spray .... it wipes off the glass pretty easily ... for a lube anyway. If you still have squeaking, proceed to remove the inner pannels and silicone any mechanical joints that you can find and the actuator. To take apart the door, look for a DIY on front speaker installation. ..... that's after you confirm that it's coming from there. Make sure that it's not from the wheel or suspension.
Old Sep 26, 2008 | 07:34 PM
HondatechAV6's Avatar
this is a common problem on the 7th gens. lower the window an inch or two and drive it. is the noise happening a lot more? typically it does. it's caused by a faulty window regulator. the noise i'm talking about sounds like a tick or repetitive tick sometimes.
Old Sep 27, 2008 | 09:59 PM
erivkin10's Avatar
Thanks falkore24 and HondatechAV6 for the quick replies.
I drove the car today and the noise was there again on the driver side. Focusing a little better, I realized it's the door glass rubbing against the gasket rubber. "Squeaking noise" is probably not the best way to describe the sound.
A few months ago I treated all the door and window rubber with Amorall. I keep them fairly clean as well as the door jambs. Is there a suggested silicone product for dressing Honda door and window rubber.
Thanks again for the assistance.
Old Sep 27, 2008 | 11:27 PM
oh, your op makes it sound like there is a noise from one or more windows when riding over bumps.
anyway, you can pick up a can of silicone spray from any honda dealer or autozone to spray the window runchannels, door seals and anything else that is rubber and my be making a little noise.
Old Sep 28, 2008 | 02:00 AM
deserthonda's Avatar
since car is still under warranty ,,i would take it to the dealer to chk things out ,make sure everything is ok..
19962door
Feb 8, 2011 07:03 PM
Planefreak
Oct 17, 2007 02:28 PM
19962door
Jul 20, 2007 08:47 AM
theNYguy
Dec 12, 2006 12:22 AM
93haccord
Apr 23, 2006 07:17 PM
