SRS Indicagtor is ON
Old Feb 9, 2010 | 04:49 PM
npverma's Avatar
Cool SRS Indicagtor is ON
Recently SRS indicator on my 2000 Honda Accord has turned on. What does it mean. How to fix it by myself any idea how much it will cost if I take it to a mechanic.
Old Feb 9, 2010 | 04:54 PM
It could be cheap or expensive depending on what problem the SRS system detected. A bad SRS unit will be expensive, a faulty seat belt buckle won't be too bad.
A scanner will retrieve the code. I am not sure if the autozone scanners will get the code, but it is worth a shot. They scan the codes for free. Post any code on here, it will start with the letter P and have four numbers. i.e. P1234.
Old Feb 9, 2010 | 09:40 PM
Are you in USA? Check your warranty booklet. I think in 2000 Honda still had "lifetime" warranty on seatbelts & airbags.
Old Mar 22, 2010 | 02:10 PM
Jeff247's Avatar
Default SRS Indicator
Will it fail inspection (New York) with the indicator light on?
Here's a Youtube video that shows how to reset the SRS indicator light:
http://www.youtube.com/watch?v=HPHu-Zhoh2E
Any info appreciated for my 2003 EX 4 cyl with 231,000 miles. Thanks
Old Mar 22, 2010 | 04:45 PM
I had a 2003 LX 4-cyl and the warranty booklet said seatbelts & airbag system warranty was "for the useful life of the vehicle". Worth a phone call to the dealer...
Old Mar 22, 2010 | 11:16 PM
hondadude's Avatar
There is a recall on the OPDS (occupant position detection system)10 year
157k Miles.
Service Bulletin 06-009.
There are also issues with the seatbelt buckle that should be covered under warranty.
Old Jul 8, 2010 | 03:07 PM
admwolf's Avatar
I recently purchased a 2000 accord with the SRS light on. Didn't think it would be a big deal, but wife's not too happy.
Will a regular OBD tool tell me the source of the light? Is there a way to determine if it is in fact the opds sensor? I don't want to get dinged with the "diagnostic fee" at the stealership. Thanks.
Old Jul 8, 2010 | 03:15 PM
It is worth a trip to a parts store like autozone to see if their scanner can read the codes. If you have your own scanner, it is worth trying.
If you get any error codes or the scanner can't get them, post that information on here, so others will know what to do.
Old Jul 8, 2010 | 06:09 PM
admwolf's Avatar
All I got was a P1298 code which I believe is unrelated. I guess resetting the SRS with the above procedure couldn't hurt. Otherwise I guess I'm out of luck.
If I do take it to the dealer, is there any way I can get them to prove to me what they gathered with their diagnostic tool? What's to keep them from telling me it's something that's not under warranty when it actually is? Yea, I've got trust issues, especially when dealing with thieves. After all, it's a lot easier for them to get their money from me than from Honda.
ecat81
Sep 9, 2007 03:14 PM
tkbalt
Sep 25, 2006 09:13 PM
accord2k
Feb 18, 2006 11:32 PM
01hondaccordlx
May 18, 2005 11:51 PM
bj70alex
Nov 22, 2004 01:56 PM
