no heat or a/c
Old Jul 8, 2010 | 06:27 PM
strk500's Avatar
Default no heat or a/c
I have no a/c or heat in the car, the blower blows, and the fans do not come on when the a/c is turned on. All the fuses are check and relay is good, any other ideas?? I just bought this car so i don't know when the last time it worked.
Old Jul 8, 2010 | 07:18 PM
What year model, etc. is your accord?
Old Jul 8, 2010 | 08:04 PM
strk500's Avatar
95 accord ex
Old Jul 8, 2010 | 08:19 PM
does any air blow out of the vents?
Get a volt meter, turn on the a/c. Unplug the electrical connector to each fan and see if there is 12V across the pins.
Old Jul 8, 2010 | 08:38 PM
strk500's Avatar
yea i was going to do that tomorrow my meter is at work, i know they do work tho, if the car sits long enough they will come on from the engine getting hot. Does anyone have the wire diagram for the compressor?
Old Jul 8, 2010 | 10:03 PM
The online manuals thread in the DIY section has a 94 shop manual that you can download from the spooner link I posted. That will have a wiring diagram. You want to look at the KH model.
You still didn't answer if air blows through the vents?
Also, does the compressor clutch engage with the compressor pulley? You should check that you get 12V to the red wire going to the compressor.
Old Jul 8, 2010 | 10:36 PM
deserthonda's Avatar
Originally Posted by strk500
I have no a/c or heat in the car, the blower blows, .
So like PA asked ,,,,,,,,,,,,does that mean that you got air blowing from the dash vents??? that answer would help a lot to diagnose your issue
can you add year and model in your sig??? 2 or 4 door, at or 5sp etc, etc
chk the heater **** ?? or possibly heater panel damage ???
skijour
Aug 15, 2012 08:31 PM
Cessna172
Nov 5, 2010 01:22 PM
vince_carnovale
Jul 18, 2008 07:38 PM
eckhart
Mar 29, 2006 09:43 PM
misterluh
Dec 3, 2005 11:02 PM
