Stalling/revving problem
Old May 29, 2013 | 01:57 PM
1990accordex's Avatar
Default Stalling/revving problem
I have a 2dr 1990 honda accord ex automatic and when I'm driving at low or high speeds I hear a loud sounds as if its stalling or over revving before it switch gears. When it switches gears I feel small small push and the speed increases a bit. If does this on every gear but drives ok. My alternator went out a few days ago and a new one is getting installed today and my steering wheel gets very hard to turn when I slow down. Can anyone help me
Old May 29, 2013 | 06:31 PM
Welcome to HAF.
Check the trans fluid, if not sure - do at least one drain and fill. Is the throttle control cable from the TB to trans adjusted properly?
PS - Honda's are picky when it comes to what fluid to use.....only use Honda/Acura approved fluid. Be sure the belt has the proper tension.
Old May 29, 2013 | 06:41 PM
Accordknown's Avatar
with the steering problem check the power steering belt and also make sure the power steering pump is functional. the pumps usually go bad when the correct fluid s not used or the pump runs dry.
corey246
Dec 13, 2012 02:34 PM
zairas
Nov 21, 2008 11:47 PM
cmm
Jun 14, 2008 09:40 AM
dricker
Mar 23, 2005 04:37 AM
