Stalls When Hot
Old Mar 19, 2013 | 10:49 AM
Lynnac1266's Avatar
Question Stalls When Hot
I have a 1999 Honda Accord, 5 speed, V-Tech 4 cylinder engine. I have replaced spark plugs with the platinum ones, spark plug wires, distributor cap, rotor, starter, air filter. Car still stalls when it gets too hot. It's not thermostat as that has also been changed. Mechanics can't find anything wrong with it. It will run well when it's cold outside, but stalls while running when it gets hot outside or when it's been running too long (2 hours). It gets scary when it stalls on the highway while doing 70 mph. What else could it be. I'm at the point of replacing whole distributor or fuel pump.
Old Mar 19, 2013 | 07:51 PM
When it stalls/dies. Does it start right back up or do you have to wait.
Also, when it dies/stalls, what lights - if any - are on in the dash?
Old Mar 20, 2013 | 07:59 AM
Lynnac1266's Avatar
I get a green key, that's it. Sometimes it starts right back up, most times I need the car to cool down for a few minutes and when it's really warm out, I need to wait an hour!
Old Mar 20, 2013 | 12:08 PM
I moved posts to new thread for better attention. In future when you have a new problem start your own thread.
Problems has symptoms consistent w/ either a worn/failing ignition switch Assy or intermittent Main Fuel Relay. PM's request to look to see what lights are visible when engine dies is key to diagnosis. No lights (Check Engine, Alt, Oil) on w/ keyswitch in ON position points toward ignition switch assy. If lights are coming on Main Fuel Relay is likely.
Silver6gen
Jul 26, 2012 07:04 PM
ladd
Nov 1, 2011 08:27 PM
emaxxman
Feb 19, 2006 03:07 AM
thejestersrace
May 26, 2005 09:21 PM
NewfieTJ
May 11, 2005 12:53 PM
