stange sound when key at ignition or start
Old Jan 13, 2013 | 12:24 AM
ngmiken's Avatar
Question strange sound when key at ignition or start
It just happens today in my 1989 Honda Accord: every time when I put the key and turn into ignition position or start the engine, a continuous sound like a fan blade touching against some metal part happens regularly until remove the key ...
Would anyone give me some idea about what's wrong with my car, and what I can do to eliminate that sound ? (Car still can be run).
Thanks
mike
Old Jan 13, 2013 | 09:40 AM
Possibly a starter issue weak starter solenoid contacts or bad battery connections (inspect and clean carefully).
Old Jan 13, 2013 | 11:34 AM
Is this under the hood or inside the car....Is the blower motor on?
Old Jun 17, 2013 | 02:31 AM
Lilitomate's Avatar
Thanks
mike
Hi, do you also have the ALB light on on your dashboard? because my Honda Accord happens to make the same noise as the one you described. The noise's on while I drive, it stops when I stop driving, even if the motor's still running. So I got my car checked by a friend who isn't a real car guy though, well apparently it's something about a part pumping some liquid into the brakes system. An ABS (ALB) pump issue. Hope that helps. If anyone else can help, I'd be grateful
Old Jun 18, 2013 | 05:52 PM
What year car do you have. Suggest you start a new thread will all of the details.
csh217
Jun 17, 2014 05:53 PM
corlyf
Sep 12, 2012 11:30 PM
blkcloud
Mar 4, 2010 01:57 PM
brofrank
Jun 9, 2006 09:16 AM
brofrank
Feb 13, 2006 02:58 PM
