Starter Replacement
Old Mar 2, 2014 | 04:08 PM
holmesnmanny's Avatar
starter contacts are $10 ... takes about 25 minutes to install
Old Mar 2, 2014 | 05:03 PM
drummer1279's Avatar
but I have a brand new starter in there
Old Mar 2, 2014 | 06:27 PM
It sounds like the rebuilt starter is bad out of the box.
If it were me, I would order one from denso. Densoaftermarket.com is where I start to get a part number. When it arrives, I would take the new starter back to AZ.
Old Mar 2, 2014 | 11:48 PM
I've already taken the AZ one back, the one I have in there now came from NAPA and its doing the same thing. I found 2 used from a honda boneyard (original not rebuilt) and am going to test a hypothesis when they arrive.
but am going to bookmark the densoaftermarket site as well
Old Mar 3, 2014 | 11:21 PM
basically I'm going to put a used starter in and see what that does since I have done everything else aside from taking it to the mechanic.
Old Mar 4, 2014 | 03:06 AM
  #17
Quit playing around and actually do some testing.
Take off the small wire going to the starter and set it on the lower radiator hose. Using alligator leads, hook the red to that wire and the black to the negative post. Set your multimeter to the 20v setting. Again, make sure it is not attached to the starter or touching anything metal in any way shape or form.
Have someone try to start the car. See if that wire gets 10v or more. If not the issue is not the starter.
Old Mar 4, 2014 | 09:57 AM
  #18
The power is fine, there isnt anything wrong with electrical system... and if you're going to scold me like a child then I would rather you not offer any more help.
Old Mar 4, 2015 | 12:14 PM
  #19
Someday74's Avatar
I just replaced the starter on my 07ex 2.4-- Went with Oriellys lifetime warrenty, because thats what my favorite mechanic use's.. It's great, Now it turns over quickly, and starts every time, just what I was hoping for-- From Slow sluggish starter, to quick and strong.
The only thing is the Knock Sensor is right next to it. You need to be very careful, it's real easy to pull the small red wire out of the thing!! (dont' ask me how I know that)- It will mean a trip the junk yard's- Or a whole new wire Loom! -- Oh and on my 07 You can't get to the 10mm nut holding the hot wire from the battery to the starter on the starter-- Not until you remove the stater and turn it away form the steel pipe that's right above it....Lot of luck..It's a lot of trouble..
Old Mar 5, 2015 | 01:15 PM
  #20
EK99HATCHBACK's Avatar
if it was me, i would have went to the bone yard from the start. the used OEM ones are still better than that reman crap they sell you at Auto Zone.
seattlehawk
Jun 6, 2009 05:04 PM
niahuynh
Apr 27, 2009 07:27 PM
mdjbhouse
Dec 28, 2006 08:31 PM
hnic514
Apr 7, 2006 10:51 PM
mcrisost1999
Jun 3, 2005 12:45 AM
