Starting Issue
Old Nov 7, 2013 | 04:57 PM
mtwallet's Avatar
Default Starting Issue
1994 Accord Dx
Im not sure where to start.I thought I might have an alternator problem, but after I jump the battery the lights stay bright.The car will start and run well for a day but over night,it won't roll over.I can't believe the battery is bad,fairly new. It's like something is draining the battery after it has been shut off.Please advise
Thanks
Old Nov 7, 2013 | 05:26 PM
Need to do a little testing.
Start by removing the battery cable at night. Attach it in the cable in the am and see what happens.....might do this over a few days just to be sure. While there, won't hurt to be sure the cables are clean and tight.
Many parts stores will test the charging system (including the battery) for free.....worth taking the car or at least the battery by one and see what they say.
Old Nov 7, 2013 | 05:50 PM
mtwallet's Avatar
Thanks,what you said makes sense,will do
Old Nov 12, 2013 | 05:03 PM
mtwallet's Avatar
Car starts fine when I leave cable disconnected overnite.So I know the battery is okay,something is obviously draining it.
Old Nov 13, 2013 | 06:11 PM
Do you have a volt meter and some time? Finding the "draw" can take some time. One thing you might check just for grins is the glove box light,
From there, as I said.....a volt meter and time.
Here is an example of the testing that will be needed: Battery Drain Parasitic Draw Testing
Old Nov 18, 2013 | 04:07 PM
mtwallet's Avatar
afraid i'm not skilled enough to read meter,would not know were to start
RDX
Feb 1, 2008 05:15 PM
Joslinm
Dec 20, 2007 08:55 PM
poser_pilot6
Jan 30, 2007 03:08 AM
99cummins
Jan 9, 2007 09:27 PM
HondaNoMore
Oct 12, 2006 08:49 PM
