starting issue with my 2000 ex
Old Aug 25, 2010 | 07:15 AM
tastebud's Avatar
Default starting issue with my 2000 ex
Just bought this 2000 accord ex and it just started having issues with starting. If the car has been sitting for an extended period it turns over but sometimes will not start. It also tends to lunge when shifting initially, but soon as it warms up it runs fine. I heard that transmission issues are common with this year, so I had the transmission fluid flushed and changed and plan on doing that every 25-30,000 miles from now on. But that should not be affecting the starting. Could this be a oxygen sensor issue or relay issue?
thanks
Old Aug 25, 2010 | 04:54 PM
Not-starting might be the Main Relay (search for that). That seems to happen when the interior of the car is hot.
Honda auto-trans do not like to be power-flushed. Drain & fill is the best way, and use Honda ATF rather than Dexron.
stubs
Aug 6, 2010 10:29 AM
Joslinm
Dec 20, 2007 08:55 PM
poser_pilot6
Jan 30, 2007 03:08 AM
99cummins
Jan 9, 2007 09:27 PM
HondaNoMore
Oct 12, 2006 08:49 PM
