steer to the right when braking!!
Old Feb 8, 2007 | 04:22 PM
kevin_nguyen0862's Avatar
Default steer to the right when braking!!
ok i have a 2001 accord v6 ex..... whenever i brake it starts to steer to the right..... even when i step on the brakes slowly..... is it my alignment guys???? please help
Old Feb 8, 2007 | 05:11 PM
deserthonda's Avatar
Default RE: steer to the right when braking!!
chk the frt brake system,, ,,, calipers piston not retracting, caliper not sliding freely in the pins ,, chk the tires as well and tire pressure
does car pull at all when NOT using the brakes
Old Feb 8, 2007 | 05:27 PM
yeah i already checked everything.... and yeah the car does pull to the right a LITTLE bit only when i dont use the brakes...... and when i do use it then it steers right pretty hard
Old Feb 8, 2007 | 07:06 PM
ORIGINAL: kevin_nguyen0862
UHMMM you checked everything eh>>?
So i am sure then, that you raised the car up and rotated both wheels in neutral to make sure that they were both spinning free
and also i am sure since you checked everything that you swapped the frt tires side to side to see if car pulled the other way
and since you did that you had the alignment checked as well ?
Shoot, since you checked everything I am out of ideas
Old Feb 8, 2007 | 09:14 PM
lol i checked almost everything i did what you said and lifted the car up and rotated both wheels in nuetral to make sure they spinning free but what i didnt do is switch both the front tires lol.... i will try and do that thanks deserthonda!!!
oldbeek
Jun 4, 2013 07:51 PM
Carmen91
Mar 27, 2008 10:13 AM
thunder_x
Jan 1, 2008 10:44 PM
Harjmarway
Feb 19, 2007 10:37 PM
oufy
Nov 23, 2006 02:03 AM
