Steering wheel clicking noise
Old Dec 13, 2007 | 09:07 AM
BlueAccord07
Default Steering wheel clicking noise
My '07 Accord EX has a little over 3k miles on it.On one frosty morning I noticed when I turn the steering wheel counter-clockwise (only) there is a little subtle "clicking" noise - this is without the blinker on. I know there is a different noise when you have the blinker on and turn the steering wheel. It does not sound like a squeal or grinding, just more like a spring being stretched or compressed is the best I can describe it.Oh, and thishappens more in the cold than once the outside temp is warmer, say 60F. I've checked most of the postings. Anyone experience something similar? Am planning to have it looked at the first oil change anyways. Thanks!
Old Dec 13, 2007 | 09:22 AM
klrspz's Avatar
Default RE: Steering wheel clicking noise
I'm a firm believer that waiting to find a problem is going to kill you in the end. (whether it be physically or your wallet)..
I'd suggest to get the codes read if anything, and at least get a quick diag before i take it around town every day...
you still have a bit to go for your first oil change, so i'd take it to the dealer asap personally.
Old Dec 13, 2007 | 06:47 PM
HondatechAV6's Avatar
it's probably the cable reel. is very cold weather you may hear it unwinding as you turn.
Old Dec 14, 2007 | 02:11 PM
BlueAccord07
Thanks! Is this something that is urgent to take in right away?
Would not be good to not have any steering control.
Old Dec 14, 2007 | 06:50 PM
the cable reel is electrical. it's a winding of cable that connects the steering wheel controls(audio, cruise, srs, horn) to the car. there is no fix, a new cable reel will probably may a little noise when it'sVERY cold.
Old Jan 23, 2008 | 02:48 PM
hatingmyhonda
i had the same problem and it was my bearingsss! not crazy expensive, 85 a pop at my mechanic. but you may want to get it done sooner than later.
-jen
Old Feb 12, 2013 | 05:49 PM
Filmar's Avatar
I had a similar issue and was related a bad O ring on my power steering. Air was leaking in and thus causing the fluid to foam an leak out the top. There was a service bulletin for my 03 Accord and I also found a helpful video. Not sure if your problem was resolved our not, but I wanted to share.
amajakgar
Aug 9, 2014 09:22 AM
L2_DJ
Oct 20, 2013 08:45 PM
loki16
Aug 12, 2013 06:54 AM
dyrrachiumus
Feb 18, 2012 04:29 PM
