Still can’t find this part !! Any ideas besides a junkyard?
Old Jan 6, 2024 | 04:36 PM
TurboLenny's Avatar
Default Still can’t find this part !! Any ideas besides a junkyard?
Somebody wayy back in 2016 couldn’t find it either and I still can’t ! Was changing out my slave cylinder and this is the connector to the line !
Old Jan 6, 2024 | 06:45 PM
Please provide us some information on your year, trim, etc Accord you drive.
Old Jan 6, 2024 | 08:49 PM
TurboLenny's Avatar
2000 accord coupe manual LX 4-cylinder !
Old Jan 7, 2024 | 10:46 AM
That adapter is not part of the OE diagram, so I'll guess that someone installed a replacement line and needed the adapter to connect to the slave cylinder.
Can you remove that adapater, or is it destroyed?
Old Jan 7, 2024 | 06:51 PM
TurboLenny's Avatar
Default Yeah it broke when I took it out !
The same thing happened to me as this guy! It broke after I punched through the little hole and took out the adapter! There was some resistance but I didn’t think it was broken! I bought a new slave but it requires that part !
Old Jan 7, 2024 | 10:28 PM
Maybe this part will work? 46941-S5A-003
EDIT: This is for the TSX and some Civics. You may want to take the fittings to a honda dealership to see what will fit in there. It looks like that adapter is part of the clutch line on the Accord diagram. Hope this adapter fits.
Old Jan 8, 2024 | 07:07 PM
This is likely part of the clutch hydraulic line.
Honda TSB 98-084
Old Jan 8, 2024 | 10:24 PM
Not sure if Honda/Acura part # 46941-S5A-003 may work. 46941-S5A-003 is usually held in with either 2 roll pins or a U-shape retaining clip. The 2000 Accord uses one roll pin.
For illustration purposes, the following are related to an Acura ILX which utilizes part # 46941-S5A-003.
Old Jan 9, 2024 | 06:34 AM
CraigDaliessio's Avatar
Default That part
Honestly that looks like a Dorman piece from the "Help" ailse at OReilly's. It's some sort of adapter. Normally that flare fitting on the hose goes straight into the cylinder without that extension. Maybe a previous owner changed that hose and got the wrong one and it wasn't long enough?
jainaashish
Nov 6, 2022 04:02 AM
Westcoastaccord
Sep 18, 2017 10:56 PM
cuberoach
Jul 14, 2012 09:41 PM
Lurch
Jan 23, 2012 09:34 AM
accrd94ex
Mar 8, 2008 02:57 PM
