199 Honda accord LX MT5 speed- hydralic clutch line issue
Old Jun 22, 2016 | 01:33 PM
Westcoastaccord's Avatar
Default 199 Honda accord LX MT5 speed- hydralic clutch line issue
hello everyone
Car: 1999 Accord LX 5 speed manual transmission 4 cylinder
Problem: need to replace the master clutch cylinder and as Ive been told the main hydraulic line at same time.
I purchased a aftermarket clutch cylinder, installed it but CANT get the freaking hydraulic line to seat perfectly so I can get the stupid PIn in and lock it in place. Ive been told that the cylinder and the line has to be changed at same time apparently for this reason.
I'm thinking I can get a aftermarket steel braided hose that will allow me more flexibility in the tight space as well as attaching the line AND pin then swiveling/ flexing it back into the tight space ( is there a trick to inserting the pin back in?)
Ive looked online but cant find anything for a 1999 Honda accord
can someone help.. please!!!!!
Old Jun 23, 2016 | 07:39 PM
I've never heard of changing the metal line when replacing the master cylinder. Did you have a problem installing the hydraulic line?
I usually install the metal line hand tight first, then finger tighten the master cylinder to the firewall.
How is the push-rod misaligned, so you can install the pin?
Old Sep 18, 2017 | 10:56 PM
SGreene's Avatar
Originally Posted by Westcoastaccord
hello everyone
For people in the future, yes, you have to replace the master clutch cylinder, the hose assembly (which is the hydraulic line) AND the slave cylinder. Factory parts no longer available they do NOT match the replacement parts. I found the parts via partsgeek.com.
vetski179
Feb 24, 2015 04:26 PM
1-Old-Man
Mar 31, 2014 10:06 AM
eduard
May 9, 2013 12:11 AM
suprarx7nut
Jun 21, 2007 12:03 AM
tamb
Jul 21, 2006 01:05 AM
