Strange air flow - Any thoughts
Old Jun 7, 2009 | 07:47 AM
BLswag
Default Strange air flow - Any thoughts
I am new to the forum and I have a weird situation. I have a 2004 accord sedan and the ac blows ice cold through the passenger side air vents, but blows warm through the drivers side air vents it is not equipped with dual zone climate control. I even set the air flow to come through the floor board vents, the air on the passenger side is ice cold, the air on the drivers side is warm. The compressor seems to be engaging, i replaced the relays in the under hood fuse box( i changed three). Could this be an issue with the climate control panel? I am stumped. Any suggestions would be appreciated. Thanks in advance.
Bill
Old Jun 7, 2009 | 08:37 AM
I have heard of this symptom arising due to low refrigerant charge, but never experience myself. The evaporator flow is low and becomes stratified, leading to cool air only over lower part of evaporator. This somehow causes air to vents to be separated into cold one side and hot on opposite side.
Only way to know for sure is to have AC pressures read (hi and low side) w/ a manifold gauge set by someone who understands what they should be. Also if refrigerant is low, it leaked out somewhere so check for leaks at connections, condensor face (rock puncture), and compressor rotating shaft seal.
byebye2u
Dec 16, 2012 07:53 AM
aussiechic2oo6
Sep 22, 2012 11:30 PM
rufryder
Feb 4, 2010 05:31 PM
rickydelcid
Dec 21, 2006 01:52 AM
cwalti
Dec 17, 2005 01:23 AM
