Strange faint buzzing hours after driving!!
Old Jun 15, 2010 | 04:55 PM
accordlad's Avatar
Default Strange faint buzzing hours after driving!!
Hi all!
I have the strangest query... my Accord (99,1.8 LS,auto) is making a faint, intermittent buzzing noise hours after being driven and parked up. It seems to be coming from the underside of the passenger rear side... I'm baffled... maybe some fuel system de-pressurising or something. The noise happens maybe every minute or two for acouple of seconds each time - its not always the same, and thoug hvery faint, sounds like 'hhmmm hhmm hmmm!!!'.
It almost sounds like a fuel pump noise, but how could this be running (even briefly) with the car off hours and the ignition off and keys out...?
Any thoughts...?
Old Jun 15, 2010 | 05:56 PM
It is probably something with the evap system. There is a valve that opens when the fuel pressure reaches a certain pressure and the vapors are trapped in the charcoal canister.
You are probably hearing the valve open. I am not sure how it is supposed to operate when the car is shut off though.
Old Jun 16, 2010 | 06:59 AM
You in UK? Passenger side = left side?
There's a valve that lets fuel vapor out through the charcoal canister (underneath the left-rear seat). It's like a check-valve to prevent air getting INTO the fuel tank, but some of them are a bit more noisy than others. You're not the first to describe a buzzing sound, but when I had a 1998 mine was barely audible "sshh" sound. I could only hear it if I closed the garage door & listened real carefully.
93Accord2.2
Jan 11, 2012 05:03 PM
charliemcfarley
Mar 24, 2009 10:20 AM
baconsum1
Nov 25, 2008 04:37 PM
nafango2
Jun 22, 2008 11:46 PM
t00fatt
Feb 20, 2008 06:20 PM
