Strange rubbing noise
Old Nov 12, 2012 | 05:12 PM
elvis1977's Avatar
Default Strange rubbing noise
I have a 2006 accord sedan 4cyl. with 73k miles. I hear a quick rubbing noise coming from the front of the car while rolling forward or backwards at very slow speeds. I hear nothing at high speeds. For example, when I first back my car out of the garage at less than 2 miles per hour I hear this quick rubbing noise that I think is coming from the passanger front of the car. Cannot reproduce this sound all the time. I have looked under the car observe nothing unusual. Other than this stange rubbing noise car drives and sounds perfect. Sometimes I hear this unusual rubbing noise while pulling forward after car has been parked. This noise is quick, but noticeable. All responses appreciated.
Old Nov 12, 2012 | 06:16 PM
Have you had any work done on the car recently?
Old Nov 12, 2012 | 06:38 PM
elvis1977's Avatar
Local Honda dealership fixed a roaring wheel bearing on driver side for 300 dollars. But this rubbing noise has been there since i bought the car two weeks ago. Senior Honda tech test drove the car and hears nothing. Hard to re-produce. A service advisor thinks it is the ABS pump making noise, but I disagree. All responses appreciated.
Old Nov 12, 2012 | 07:53 PM
Brakes? They can make quiet rubbing sounds at slow speeds, that's normal.
Old Nov 12, 2012 | 08:50 PM
elvis1977's Avatar
I've owned cars for many years and have never heared this sound on a car rolling slowly. Very strange.
Old Nov 12, 2012 | 10:14 PM
earlflux's Avatar
My 2005 accord had a rub noise once. It was a metal shield inside the front passenger rotor. My friend grabbed it and bent it away from the rotor a bit. Something to check maybe.
Old Dec 2, 2012 | 07:18 PM
elvis1977's Avatar
Default Strange Pumping Noise
The strange pumping (rubbing noise) is coming from the ABS device under the hood on the passenger side. It pumps only once when I first start the car and move forward or backward in or out of gear. It makes this rubbing (pumping sound) EVERY time I start the car and move forward or backward. Sound only lasts for 1 second. No ABS light on dash. Car runs and brakes normal. Should I be concerned? Anbody else seen this situation before?
Old Dec 3, 2012 | 06:25 PM
elvis1977's Avatar
Default Buzzing noise resolved!
The buzzing noise is coming from the ABS running a self test according to a Honda shop foreman who test drove my car today. It runs this self test after every ignition startup driving slowly forward or backward for 1 second and does not run the test again until you start the car again. Thanks to all who responded.
Old Dec 3, 2012 | 08:08 PM
jroxz44's Avatar
Almost A Senior Member
I disabled my ABS. I hate it in the winter time you can never stop.
zedjr
Jan 14, 2013 01:25 PM
rjnyc
Feb 21, 2010 07:12 PM
joncnca
Aug 15, 2009 09:12 PM
BLACKKETYL
Jan 14, 2008 08:15 AM
FlyLow
May 8, 2006 06:00 AM
