STUCK CLUTCH - 2004 accord
Old Sep 5, 2011 | 12:13 PM
libra2458's Avatar
Default STUCK CLUTCH - 2004 accord
my son just had a new engine put in his 2004 accord a month ago. yesterday he called me and said that his clutch was stuck all the way to the floor and he fears he needs a new clutch. he said that he had a new clutch put in 2-3 years ago.
any help, advice is appreciated.
Old Sep 5, 2011 | 12:24 PM
Clutch is hydraulic. Most likely not installed correctly or damaged leading to leak which allows clutch pedal to fall to floorboard. Should be relatively simple fix.
Old Sep 5, 2011 | 01:28 PM
libra2458's Avatar
Thanks. He just told me that he noticed that after he had the new engine put in, that is when he started having problems with the clutch. He is going to call the mechanic that put in the engine and take it from there. The good news is that with the new engine the car runs like a dream!!
Old Sep 5, 2011 | 02:10 PM
How did this engine fail? I've heard of relatively few failures of these models? I4 or V6? Hard driiving?
regards
Old Sep 5, 2011 | 03:39 PM
libra2458's Avatar
regards
V6 = He bought it used and always had problems with oil leaks and needed to add oil. Every oil change car was checked for leaks and none could be found. He had work done on it about a year ago which was suppose to solve problems with the car, but it did not. New engine was put in 3 weeks or so ago and car ran wonderful (until this happened with the clutch). He loves the car even with the problems he has had.
Old Sep 5, 2011 | 04:00 PM
Thanks for input.
regards
Old Sep 5, 2011 | 10:39 PM
libra2458's Avatar
The teenage brother of a friend suggested that he tie a nylon cord to the clutch and use it to pull the clutch up until he can get it looked at. He posted the video on his facebook page and it seems to be working!! Cheap fix for now.
Thank you to all of you who have made suggestions, not only to this post, but to my post about cranking problems I am having with my accord. Your input, ideas and suggestions are truly appreciated!!!
Old Sep 12, 2011 | 10:21 AM
libra2458's Avatar
UPDATE: Mechanic that put in new engine is fixing problem today.
Old Sep 12, 2011 | 12:48 PM
bigpat's Avatar
Almost A Senior Member
Change the clutch slave cylinder...Make sure to bleed it correctly.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
Dogro
Feb 24, 2011 05:36 PM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
