Surface rust
Old May 17, 2015 | 02:50 PM
Devilgreeneyes's Avatar
Exclamation Surface rust
06 Accord
On the bottom right corner of my hood (grill and headlight), I have a quarter size spot I want to fix before it becomes a problem. I bought a bottle of match paint from Advance Auto. Also have a sheet of sand piper. What is the best way to go about this? I have a bug shield that will be going on after this spot is taken care of. Thoughts please
Old May 17, 2015 | 02:53 PM
Get some primer to apply after sanding, let primer dry before applying paint.
Old May 17, 2015 | 02:55 PM
Not to sound silly but how do I actually sand? Wax on wax off style?
Old May 17, 2015 | 03:08 PM
Prospector's Avatar
There are a number of 'how to' videos on uTube available about auto rust removal
Old May 17, 2015 | 03:55 PM
This is a good guide. You can just use the touch up paint you have without spraying, after sanding and priming.
How to Repair Minor Rust on a Car: 10 Steps (with Pictures)
Old May 20, 2015 | 07:50 PM
EXV6NIGHTHAWK's Avatar
The bottom ends of these hoods are double layer, so it is difficult to get all the rust without making a hole through both layers. Good luck, but the rust may come back. A new/used hood might be the only permanent solution.
MessAround
Jan 13, 2014 06:24 PM
dannyrl
May 31, 2012 10:08 AM
Kuzma Prutkov
Jul 20, 2009 07:44 AM
otto63
May 5, 2005 06:30 PM
Apr 18, 2005 02:03 AM
