surging rpm at highway speeds vs. slipping transmission?
Old Oct 31, 2007 | 05:14 PM
deserthonda's Avatar
Default RE: surging rpm at highway speeds vs. slipping transmission?
also you might be experiencing what is called torque converter hunting.........
make sure that the throttle cable adjustment going to the tranny is correct
Old Oct 31, 2007 | 07:54 PM
thunder_x's Avatar
interesting suggestions, thanks
i will look into all of these
and btw, my car is internal coil
Old Nov 1, 2007 | 04:06 PM
thunder_x's Avatar
i resetted my ecu and it didnt seem to make a difference.
Old Nov 1, 2007 | 04:49 PM
If the idle screw is maxed out, and your idle is still low, then not enough air is getting to the intake.
Is your air filter clean? You can take off the idle control valve and clean that out. There is a screen on there that can have carbon buildup on there. Try not to douse the IAC, just spray through the screen and allow to flow out.
Cleaning the throttle plate (both sides) with a toothbrush can also help with strange idle problems.
Old Nov 1, 2007 | 06:24 PM
thunder_x's Avatar
my filter is fairly clean
i cleaned my throttle body and throttle plate recently, but i dont think i cleanned it all the way, because if i had taken it apart, it would have been better. it's ok thought, because i might get an h23 throttle body soon
where is the idle control valve?
is that the same as the fast idle valve?
and i think that the problem might be from the idle speed control, because my idles are weird alot
sometimes it will idle low, then sometimes it will idle perfect. and other times it will idle high or surge.
Old Nov 1, 2007 | 10:20 PM
Its on the front of the resonance chamber. If you go to a site like www.hondapartsdeals.com and look up parts for your car its under engine, throttle body. Its called 015 VALVE ASSY., ELECTRONIC AIR CONTROL
Old Nov 2, 2007 | 06:11 PM
  #17
thunder_x's Avatar
isnt that the same as the idle speed control?
wunderbra
Mar 15, 2011 11:13 AM
SI_dude
Nov 18, 2010 08:39 PM
wackoR
May 4, 2008 10:23 PM
00AccordLX5spd
Mar 22, 2007 06:36 PM
sanchezcruz_20
Jan 30, 2007 02:43 PM
