Switch Key Fob Numbers?
Hi all – – I have a 2011 Honda Accord coupe that I bought used and it only came with the number two key. So when I open the car with the key it defaults to the number two driver position. I’m fine with it, but I was wondering if there was a way to change it to number one. I called Honda service and they said I would have to get an entirely new key.
I found this on Google and it sounds like I might be able to reprogram the key to lock and but might end up locking myself out without programming it at Honda. Any ideas? Thanks!
https://www.google.com/search?q=can%27t+I+switch+my+Honda+key+fob+number+ two+and+make+it+number+one+%2B+honda+accord+2011&s ca_esv=1e618ffcd8ec6d84&iga=0&hl=en-US&sxsrf=AHTn8zpQjcDkuLaDzWAUPj-wgwSsxAZEIw%3A1745864214517&ei=FsYPaN-nH87S5NoP9KekAQ&oq=can%27t+I+switch+my+Honda+key+f ob+number+two+and+make+it+number+one+%2B+honda+acc ord+2011&gs_lp=EhNtb2JpbGUtZ3dzLXdpei1zZXJwIlVjYW4 ndCBJIHN3aXRjaCBteSBIb25kYSBrZXkgZm9iIG51bWJlciB0d 28gYW5kIG1ha2UgaXQgbnVtYmVyIG9uZSArIGhvbmRhIGFjY29 yZCAyMDExSNWFAVDRD1i3fnADeAGQAQCYAbQBoAGkFKoBBDIuM Tm4AQPIAQD4AQGYAgKgAgnCAgoQABiwAxjWBBhHmAMAiAYBkAY IkgcBMqAHsQeyBwC4BwA&sclient=mobile-gws-wiz-serp#pi=can't%20I%20switch%20my%20Honda%20key%20fo b%20number%20two%20and%20make%20it%20number%20one% 20%2B%20honda%20accord%202011&sbfbu=0
Not worth the risk of bricking your currenty key for DIY work in my opinion especially since you can keep your settings as passenger 2.
I would think that could be programmed. Maybe contact a locksmith for a quote on programming the current key. The additional cost for a spare key may also be worth it.
You may want to look in the owner's manual to see if there are any instructions on the passenger 1 vs passenger 2 key settings. Maybe there is something in the menu system to program?
