Temperamental reverse lights
Old Sep 28, 2014 | 09:50 PM
Bforbesut's Avatar
Default Temperamental reverse lights
94 accord 5 speed, reverse lights come on when it is almost in gear but not quite but then turn off when I get it all the way into gear. Any ideas?
Old Sep 29, 2014 | 09:43 AM
Probably an intermittent transmission reverse switch. You can short the connector to the switch and confirm light stays on all the time. Fix by replacing switch unless an intermittent circuit is discovered.
From shop manual it's on top of trans underneath lower radiator hose. You will likely need a deep socket to remove.
mclrh2o
Sep 17, 2010 05:45 PM
pbplayer257
Jun 17, 2010 11:15 PM
Stoenr
Jan 29, 2009 03:24 PM
Allmetalweaver
Jul 3, 2007 08:17 PM
waynewonder
Dec 20, 2005 03:43 AM
