Throttle Cable Issues
Old Jul 3, 2013 | 11:34 AM
knotty226's Avatar
Default Throttle Cable Issues
Hey guys, I'm new to cars in all n not sure if I posted in correct section. Well my throttle cable is very slack. It is loose where the cable enters the passenger side firewall. I have tried adjusting the two bolts/nuts that contol the tension of the cable but the chord is still slack. I assume that the slackness of the chord is the reason why my car jerks while it shifts through gears. I tried to adjust the cable near the firewall but it won't stay in the firewall. Is there something broken in between the gas pedal and the firewall?
Thank u in advance for all assistance.
Old Jul 3, 2013 | 03:41 PM
The throttle cable and AT throttle control cable must be adjusted together to get throttle plate and throttle control arm to begin moving at same time.
See DIY forum, Online Manuals post for download manual for 94-97 Accords. This has adjustment procedures.
Throttle stop screw should not be adjusted.
Old Jul 4, 2013 | 01:44 AM
TexAS Honda has got your answer above correctly posted for you..
Should work out A okay!
Old Jul 5, 2013 | 10:04 AM
knotty226's Avatar
Thanks a bunch. I will try to work on it this weekend.
pr1madona
Feb 23, 2014 11:26 AM
sneekz206
Mar 5, 2011 07:02 PM
clutch811
May 24, 2008 09:35 PM
rloden
Apr 5, 2008 07:47 AM
Mrheat
Nov 11, 2007 08:12 AM
