Tie-Rod to knuckle arm bolt?
Old Dec 11, 2008 | 10:54 PM
jpdfly
Default Tie-Rod to knuckle arm bolt?
Also posted this in suspension, sorry if I put it in the wrong place...
1994 Honda Accord EX
Good evening all,
New to these forums, so if this has been covered before, I apologize, and please direct me in the right direction if possible. I heard a noise when turning and going over not so flat and even roads today, so did some inspection when I got home, and I think I have found the cause. When looking at what I believe is the tie-rod attaching to the knuckle arm on my right front tire area, I saw this bolt or nut or whatever it is missing some of the rubber washers or boots on it, and it had plenty of play in it when I touched it. Upon looking at the right hand side, I saw that it had 2 extra rubber washers or boots, and no play whatsoever with the nut. I have attached pictures, and my question is fairly simple...can I just replace this nut, if so, what is it called and can I get it from auto zone or someplace like that? If not, well...yeah...
My steering and alignment hasn't seemed to have been affected at all, so I'm hoping I don't have to replace the entire tie-rod...just need to know about the nut or bolt or whatever it is for now. Thanks
JPD
[IMG]local://upfiles/19420/3C281033371B49298C36958A2C77C881.jpg[/IMG]
[IMG]local://upfiles/19420/C698C6BEFEBA43AABC2C38045CCF7E80.jpg[/IMG]
[IMG]local://upfiles/19420/EF76696B92C848D8BD41289897DB936B.jpg[/IMG]
Old Dec 13, 2008 | 11:18 AM
Am4wag's Avatar
Default RE: Tie-Rod to knuckle arm bolt?
That's your sway bar end-links.Just changed a pair on a '92 DX.Pretty much when you buy them,they're a 3/8" bolt,nut,flat washers,spacers,and the rubber.However,the stock ones are a different configuration,and are metric.
kennilope
Apr 20, 2010 05:25 PM
jpdfly
Dec 12, 2008 08:50 AM
ArcticHonda
Feb 17, 2007 02:57 AM
Tony1M
Jul 3, 2006 08:12 PM
aka1109
Jan 10, 2005 02:19 PM
