Tie-Rod to knuckle arm bolt?
Old Dec 11, 2008 | 10:40 PM
jpdfly
Default Tie-Rod to knuckle arm bolt?
Good evening all,
New to these forums, so if this has been covered before, I apologize, and please direct me in the right direction if possible. I heard a noise when turning and going over not so flat and even roads today, so did some inspection when I got home, and I think I have found the cause. When looking at what I believe is the tie-rod attaching to the knuckle arm on my right front tire area, I saw this bolt or nut or whatever it is missing some of the rubber washers or boots on it, and it had plenty of play in it when I touched it. Upon looking at the right hand side, I saw that it had 2 extra rubber washers or boots, and no play whatsoever with the nut. I have attached pictures, and my question is fairly simple...can I just replace this nut, if so, what is it called and can I get it from auto zone or someplace like that? If not, well...yeah...
My steering and alignment hasn't seemed to have been affected at all, so I'm hoping I don't have to replace the entire tie-rod...just need to know about the nut or bolt or whatever it is for now. Thanks
JPD
[IMG]local://upfiles/19420/4AA5BFBB68A346B4BB1A8C3945F95BF6.jpg[/IMG]
[IMG]local://upfiles/19420/658336EA9B7649AB8CFB79D8E40D70B9.jpg[/IMG]
[IMG]local://upfiles/19420/CA5B473A7467454BAAAA23B217E0E304.jpg[/IMG]
Old Dec 11, 2008 | 10:50 PM
jpdfly
Default RE: Tie-Rod to knuckle arm bolt?
Forgot to mention that it's a 94 Accord EX
Old Dec 12, 2008 | 12:47 AM
JohnL's Avatar
It's the front anti roll bar (aka swaybar) bushes. You sound like you have near zero mechanical experience, so I suggest you take it to a mechanic to have them replaced (bushes only). It will be a quick and cheap job unless the mechanic sees you coming...
Old Dec 12, 2008 | 07:10 AM
jpdfly
Ah, now I see why I couldn't quite figure that out...I do have mechanical experience, just not with road vehicles I guess you could say...so this is my attempt at fixing this thing on my own...there's a DIY shop on post that I'm going to go to tomorrow to see if they have the tools for me to get it on my own. I appreciate the help.
JPD
Old Dec 12, 2008 | 08:50 AM
finch13's Avatar
I think you'll find that it's a very easy job. As long as the shop you have on base on whatever has metric wrenches, youre all set. You'll need a 12mm and a 10mm, I think... maybe a 14...
It's basically just a long bolt, some washers, rubber bushings and a nut. You can find them online for about $11 a pop, I suggest tasauto.com or rockauto.com.
kennilope
Apr 20, 2010 05:25 PM
jpdfly
Dec 13, 2008 11:18 AM
ArcticHonda
Feb 17, 2007 02:57 AM
Tony1M
Jul 3, 2006 08:12 PM
aka1109
Jan 10, 2005 02:19 PM
