tight oil pan drain plug
Old Feb 15, 2008 | 04:10 PM
jgomez630
Default RE: tight oil pan drain plug
I had this issue also. I think some mechanics tighten them with an air gun to the point where I
had to replace the oil pan because they put a small , hair-line crack right next to the drain plug. You can also try using a rachet with a long bar for more torque to loosen the plug.
Old Feb 15, 2008 | 11:51 PM
LCSeminole's Avatar
Once you get it off, make sure you replace it with a new OEM drain plug and crush washer. If you have a torque wrench, be sure to look up the torque setting in the owners manual and don't tighten the plug more than the setting calls for. For example, my 2000 EX-V6 calls for 29 lb/ft. If you overtighten, you will begin to strip threads.
alltime3rdwheel
Dec 31, 2012 10:46 AM
db12
Apr 26, 2012 12:07 PM
greg9442
Oct 15, 2009 10:37 AM
jon02accord
Mar 26, 2008 10:54 AM
desi01
Jun 24, 2006 05:49 AM
