Timing belt change?
Old Mar 18, 2006 | 04:30 PM
rick55's Avatar
Default Timing belt change?
Hey everyone,
My wife has a '97 Accord with 58k on it. I was not planning on changing the timing belt until it hits around 90k or so, but I'm a little concerned about how old it is (9 yrs). Should I change it now or do you think I could go til 80 - 90k before I do it?
Thanks,
Rick
Old Mar 18, 2006 | 06:18 PM
RTexasF's Avatar
Super Member
Default RE: Timing belt change?
Change it now, you are correct that the time factor plays in this also.
Old Mar 18, 2006 | 06:30 PM
lightshow's Avatar
yes neoprene rotts out after time....get it changed
Old Mar 18, 2006 | 06:51 PM
mbo1985's Avatar
Yeah, listen to the advice. Don't forget the water pump too!
Old Mar 18, 2006 | 07:15 PM
Markus26's Avatar
just did mine with 64k on it. mines a 97 also. change the timing belt, water pump, balance shaft belt (get the oil seal retainer from the dealer if it hasnt been done already), and drive (ac,alt / PS) belts.
Old Mar 19, 2006 | 02:12 PM
deserthonda's Avatar
along with markus parts suggestion . add a valve cover gasket and you might as well replace the camshaft seal..
Old Mar 19, 2006 | 07:11 PM
Maimster's Avatar
I wish you guys were around me when I drove my car to long until the dam belt POPPED! 2.8K in damages!!! 20V system with 12 bent! Not a pretty thing at all.
Old Mar 19, 2006 | 10:04 PM
mbo1985's Avatar
My friend just broke his jetta's timing belt. Not a pretty sight. A very important lesson in preventive mantainence indeed.
Old Mar 20, 2006 | 12:41 AM
http://www.cybertrails.com/~puf/Hond...meBalNote.html
read this ,, hope it helps..
KincaidChance
May 3, 2011 01:13 AM
Tony1M
Apr 1, 2007 05:42 PM
dinzer
May 19, 2005 12:07 AM
GolfingTiger
Mar 16, 2005 05:41 PM
