Timing Belt? Help!
Old Jan 8, 2012 | 02:27 PM
OakdaleHonda's Avatar
Default Timing Belt? Help!
I have a 1987 Honda Accord Lxi with 87,000 original miles. Yes, crazy I know - dad didn't drive it much. Well, driving the other day when I hear a loud screech, and then car stalls. Try to start it up again, and it screeches and won't start. Open up the hood, and there is oil splattered all over the right side of engine. Thinking the timing belt went, but wanted to get other ideas of what I should be looking to fix. Thanks!
Old Jan 8, 2012 | 03:53 PM
Despite, miles you are way overdue for a timing belt. To check timing belt, remove the oil fill cap and see if you can see the camshaft turning when engine is turned over. If yes, the timing belt may be OK.
Screeching could be a bad starter.
good lukc
Old Jan 9, 2012 | 06:00 PM
Usually when describing left and right of the car it is as if you were sitting in it.
2 dr (coupe or hatch) or 4 dr.....I kind of like the 3rd gens
Old Jan 9, 2012 | 10:23 PM
Roader's Avatar
Power steering pumps can make a hell of a screech when they cavitate plus fluid pukes all over. Pump seized?
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
