Timing belt kit
Hello!
I am in the process of changing my timing belt and water pump on my 96 accord lx 2.2L 4dr 4cyl. When looking at kits, i see that there are a couple of different options. With 300,000 miles, i will be changing tensioners and pullies as well. Is there anything else I should be changing along with this service?
Thanks in advance!!!
I moved this to General Tech where more people will probably look at it.
If your engine doesn't already have a retainer for the balance shaft seal, that's a good thing to get.
Since you have to lift the valve cover to get the upper timing cover off, how about a valve cover gasket? They get hardened with age & heat.
I'd probably do the plugs, cap and rotor too, since the car will be down for the afternoon (it takes about 5 hours to change the belts and water pump).
Before you start, go to Autozone and rent their harmonic balance/lower pulley tool for 50 bucks, as you'll need it to get the lower pulley off, as the crank bolt is torqued to at least 150 ft lbs.Note; take off the left front tire, as you'll be doing everything thru the wheel well opening. As for the 6mm by 200mm pin, I used a 7/32nds long handle allen wrench to lock the rear balance shaft, as it fit just fine, and you need it to do the balance shaft portion of the job.
I hope this helps.
