Timing Belt Makes Whining Noise When Accelerating
Old Apr 23, 2019 | 02:55 PM
The Toecutter's Avatar
Originally Posted by hmr
I reported the whining noise coming from within the timing belt cover. Quite noticeable when accelerating. The mechanic says that the whining noise is caused by the timing belt being too tight. He needs to adjust the tensioner which he'll do later this week. How long should it take him to do this ? Thanks !
On average it could be as little as 15 minutes, or as long as an hour. It really depends on whether he can access the tensioner nut.
Old Apr 24, 2019 | 05:39 PM
hmr's Avatar
hmr
Thanks. It took him an hour. Couldn't see much but the left front tire was removed. Components in the left front engine area were removed with the car up and down on the hoist a couple of times.
Old Apr 26, 2019 | 04:30 PM
NMinop's Avatar
Could it be the belt tensioner? I've read posts about that causing the whining noise. I too have the same sort of thing - at first it kind of bothered me, but I've grown to not have a problem with it. At some point I might address it after I do some more research. Can anyone comment on the tensioner, or have prior experience with that being a problem? There's a good youtube video on replacing it.
Old Apr 27, 2019 | 10:38 AM
I replace the tensioner when I do the timing belts. That way I know it should be good. Some people just replace the belts and re-use the tensioner. It can be done either way. Honda recommends replacing the tensioner and spring and the water pump when doing the timing belts. I also add the balance shaft retainer clip while I'm in there now. I only say that, as I've had the balance shaft seal push out, and dump almost 3 quarts of oil in 30 feet at idle before (on my wife's Accord).
barryfaetheus
Apr 29, 2011 05:43 PM
iDrive1994CD6
Apr 23, 2011 08:45 AM
Hondalover
Mar 14, 2011 03:04 PM
Tony1M
Apr 1, 2007 05:42 PM
cgarcia275
May 15, 2005 07:47 PM
