timing issue on accord
Old Mar 24, 2008 | 03:55 PM
jasonsaccord
Default timing issue on accord
i changed the oring on the back oof the distributor today. now the car willnot crank. yes the plug wireswere put on correctly i marked the wires on the cap. the car ran fine until i parked it 2 weeks ago to drive my truck for a few weeks. is there any way i got it out of time? any help is greatly appreciated.
1990 accord
2.2
5 speed
dx
197,500 k
Old Mar 24, 2008 | 03:59 PM
Default RE: timing issue on accord
The blade on the distributor shaft is a bit offset from center, so it's not supposed to go in backwards. But it WILL go in backwards if you hammer it into place. It should slide nicely into place.
But even if that's backwards, the engine WILL CRANK. It will crank until the battery goes dead but won't fire up & run.
Did you let the battery go dead? Or at least low enough that your radio etc. works but not enough juice to run the starter?
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
