Tire question please Help
Old Dec 17, 2008 | 09:31 PM
rtran19's Avatar
Default Tire question please Help
Drive a 99 accord sedan. Not sure which set of tires but whenever i drive straight they make a buzzing noise and whenever i would turn or on a curve its pretty quiet. very weird. and i have noticed my mileage have dropped by 5mpg which is pretty significant. is there a correlation between those two? please help!
Old Dec 17, 2008 | 11:53 PM
cjdm98's Avatar
Default RE: Tire question please Help
This may sound odd,but are your tires properly inflated?And typical noise from the tire is normal.
Old Dec 18, 2008 | 12:45 AM
kris_loehr's Avatar
Sounds like a wheel bearing. Tire noise should not change when you turn but a wheel bearing will.
Old Dec 18, 2008 | 03:34 PM
rtran19's Avatar
tires are properly inflated
Old Dec 18, 2008 | 03:37 PM
rtran19's Avatar
weird thing is after i got my brakes changed in the front, thats when the lost mileage and noise happen. can you educate me on what a wheel bearing does?i would appreciate it
Old Dec 18, 2008 | 03:39 PM
finch13's Avatar
Outer ring of the bearing sits in the hub carrier/steering knuckle; the inside of the bearing sits on the axle (in front) or hub (in back). It allows the cars wheels to spin freely and with little frction.
Maybe your brakes are dragging... slide pins need a relube?
kshaw74
Sep 15, 2014 01:44 PM
mamtsberg
Mar 17, 2010 09:15 PM
bsdeshaies
Jan 19, 2009 03:02 PM
Stoenr
Mar 29, 2008 09:23 PM
ckebottle
Jul 24, 2007 01:21 PM
