Tire Wear Issue & TCS Light On
Old Mar 2, 2014 | 01:12 PM
Bear2's Avatar
Default Tire Wear Issue & TCS Light On
I too am a newbie. 2 problems with my 2003 accord v-6. After getting new tires- driving off the lot my tcs light came on with orange !triangle.excessive wear now on front passanger tire has made me replace 4 tires. Been to 3 different shops that claim alignment is fine. i've replaced ball joints, arms and struts. Any idia why tire is wearing and how to fix tcs. could the tcs be causing the wear ? no abs light HELP!!! Thanks
Old Mar 2, 2014 | 02:00 PM
See posting rules. When you have a new problem, start a new thread.
Suggest posting your alignment numbers. Any accident history or curb impact history? How is tire wearing; outside, inside, both edges, middle?
Regarding TCS, there are several faults associated w/ TCS Activation Indicator (triangle) On only (no ABS or TCS Indicator); 64, 65, 66, 68, 83, 84, 86). You will need to access codes to know which is causing DTC. See following link (DIY: SRS Codes and reading them. - Club RSX Message Board).
Post codes for additional help.
A shop manual (automanualsource.com) will help you understand meaning of above DTC's.
Old Mar 2, 2014 | 02:27 PM
Bear2's Avatar
Default codes given but alignment ok
Although tcs and warning lights were on before trani went out... the codes trani shop gave me were as followed
51-01 abs pump motor
61-01 batt voltage malfunction (new battery)
84-01 sensor logic malfunction
No history of tire of wrecks. I'm second owner
Old Mar 2, 2014 | 02:47 PM
How about the wear on the tire? Post some pics as well.
Old Mar 2, 2014 | 05:32 PM
Suggest monitoring your battery voltage w/ an Equus Battery Monitor.
Equus Innova 3721 Battery Charging System Monitor - Walmart.com
High or erratic voltage might cause TCS problems.
John R
Aug 6, 2010 07:46 AM
vtecHef
May 16, 2007 01:10 PM
fireballer44
Jul 25, 2006 03:22 AM
elvis
Jul 11, 2006 06:03 PM
