TPMS Valvet
Old Apr 8, 2012 | 02:18 PM
rah140's Avatar
Default TPMS Valvet
2012 Honda Accord,
I didn't have a torque wrench handy when I installed the TPMS valve. I tightened the nut snugly with a socket and didn't over tighten it on the alloy wheel. The rubber gasket around the valve stem looked normal after I tightened the nut. Will this pose a problem in the future because I didn't tighten it to the exact specifications?
Old Apr 8, 2012 | 04:13 PM
As long as the there is no air leaking from the grommet area of the valve, then it is not a problem. But, if it starts to leak, then get a new valve grommet and new washer for the nut. Do not re-use the old grommet if it leaks, over-tightening the nut can also damage the grommet.
jonmnorman
Aug 5, 2009 06:59 AM
abptltypes02
May 23, 2009 09:46 PM
bobz
Sep 27, 2008 11:57 PM
cigarlvr
Aug 1, 2008 08:57 AM
accordion
Feb 23, 2008 03:01 PM
