tranny filter
Old Oct 28, 2009 | 03:37 AM
Et5291's Avatar
Default tranny filter
i am planing on taking the pan of my transmission tomorrow. my transmission slowly but surely stopped shifting so i flushed the fluid and it started working again.... for a little while.... my filter was never changed is it possible my tranny isnt blown its just my filter? that would save me tons.
95 accord lx non vtec
Old Oct 28, 2009 | 07:48 AM
Good luck with that.
Honda auto trannys don't have a pan. The "filter" is an internal screen of sorts, & you have to remove & dismantle the tranny. It's NOT a routine replacement.
Did you have it power-flushed? Hondas don't seem to like that. Drain/fill a few times & drive 20 miles between.
Did you use Honda ATF?
Old Oct 28, 2009 | 06:07 PM
Et5291's Avatar
i didnt have it power flushed and i did indeed use honda atf for it. the tranny went out on my once when i was driving like i lost everything no gear what soever. then i let it sit for a few minutes and i got it back but only up to like 25 mph then it died out again. i changed the fluid then it ran great for a few days then died out again so idk what the problem could be yet.
Old Oct 28, 2009 | 06:15 PM
Et5291's Avatar
if i could figure out the root of the problem it would be nice. Im not conviced that the tranny is blown yet or even close. then again i dont know enough about the transmission to make that diagnosis. does that screen usually get cleaned when you put in new fluid? or how can i save my self form spending 1500 to get it rebuilt
Old Oct 28, 2009 | 08:54 PM
kris_loehr's Avatar
When you said it died can you clarify? Does it feel the same as neutral and you can rev the engine freely and no movement of the vehicle?
Old Oct 29, 2009 | 04:41 AM
Et5291's Avatar
i can shift the stick into whatever position i want and rev the engine. neutral or any of the other ones as of now. when i said it slowly went out i used to be able put it in gear (d4 or reverse) and if i waited 10 seconds or so it would pop into gear but i wouldnt be able to drive far before i lost it again. ( after it warmed up) so its a paper weight right now. i start it ever yonce in a while just to remember how things were lol. but yes i can definetly rev it
Old Oct 29, 2009 | 03:12 PM
kris_loehr's Avatar
I can see why you were looking for a filter.
Old Oct 29, 2009 | 03:16 PM
Et5291's Avatar
yes siree lol
Special_K
Aug 12, 2011 04:16 PM
big B
Apr 9, 2011 11:14 AM
bjr001
Mar 5, 2010 07:31 PM
tranwreck
Apr 30, 2009 09:27 AM
