tranny problems. need advice.
Hi all, please excuse me if I am not posting this in the right domain. I bought a 97 lx auto accord w/ 130k mi on it a couple months ago. 3 months later the tranny failed. I had the codes PO715 and and PO740. My mechanics recommended that I do a tranny swap. So I had a JDM tranny put in with supposedly only 30k on it. I did not replace the input speed sensor though. I noticed the check engine light was still on and that it shifted hard. Jolts when switching gears. Shifts late when I decelerate or break. Got it tested and I pulled the code po715.. So, my question. Do you think JDM gave me a shot tranny? or should I dish out 100$+ to replace the input speed sensor? hopefully that will take care of the hard shifts? Thanks.
agreed, follow the codes
excellent advise
on another note, i had a Dodge Caravan in my shop the other day, replaced rack and pinion and leaking intake gasket, unplugged 6 connectors to do the job, upon startup it threw codes at me (scanned it before repair, no codes) injector 2 and 6 open, temp switch open causing fan to constantly run, cleared codes, injectors recalibrated, temp switch needed replacement.
sometimes you unplug it it doesnt return.
excellent advise
nutterbutterlover
Jul 17, 2013 06:36 PM
