Transmission hard to shift at 35 miles
Old Dec 12, 2011 | 02:50 PM
1magiced's Avatar
Default Transmission hard to shift at 35 miles
I have a 96 honda accord, 2.2L 4 cy auto trans. I got it from my brother who had the transmission replaced. The check engine light is on and when driving the vehicle going into the 30mph range, it revs to about a 3.5 and up on the tach. I literally can rev the engine as if it were on neutral and not travel anywhere. After some reving, the transmission catches gear and rides fine. But after a complete stop, to get to full speed is a nightmare. Any ideas?
Old Dec 12, 2011 | 03:22 PM
Roader's Avatar
Check the CEL code(s.) If you don't know how, click on the "Common DIY" sticky, the first thread on this forum, then click on "How to Check CEL Codes." It's pretty easy to do; your '96 has a blue connector behind/underneath the glove box.
Is the fluid level within the hash marks on the transmission dipstick when the car is warmed up but not running?
Old Dec 12, 2011 | 10:34 PM
1magiced's Avatar
The fluid levels are good, the codes and message are as follows - p0715 input/turbine speed sensor A circuit and p0740 - torque converter clutch circuit/open
Old Dec 13, 2011 | 11:00 AM
Roader's Avatar
"http://www.hondahookup.com/forums/showthread.php?t=164415"
"https://www.hondaaccordforum.com/forum/general-tech-help-7/1996-trans-doesnt-like-shift-anymore-36695/"
Maybe you'll get lucky & the mainshaft speed sensor circuit will be open. Since the trans was recently replaced you may want to ohm out the wiring too, if the sensor is in spec.
Non Quixote
Jun 3, 2015 11:34 AM
panoman
Dec 7, 2012 06:45 PM
egonzal24
Jan 3, 2008 06:46 PM
cache
Apr 16, 2006 04:43 PM
cpowers
Apr 3, 2005 10:19 PM
