Transmission issue
Old Sep 5, 2009 | 07:28 AM
shermanreed
Default Transmission issue
I have a 93 Honda Accord LX with an automatic trany - the other day I hydroplaned into a ditch which had lots of water and mud and weeds in it. The first day I got it from the tow yard it ran fine. The next morning I go to drive it and it has park, reverse, and only second gear. After about 20 min of this it starts shifting fine - all day and all night - not one problem. This morning I get in it and the same thing happens - park, reverse, and only second gear. This time it has not started shifting correctly. Can anyone help?
Old Sep 5, 2009 | 08:59 AM
Your ATF may be contaminated w/ water. I would drain and replace all the trans fluid w/ procedure as described in following link.
http://en.allexperts.com/q/Honda-Rep...rans-flush.htm
When you separate one of the trans cooler lines, you will have no way of knowing if it's the supply to the radiator or return from radiator, so a check is necessary. Manual doesn't identify which is which.
This allows a close as possible complete displacement of all old ATF.
good luc
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
MACCLES
Oct 17, 2006 07:57 AM
