Transmission Leak
Old Mar 12, 2008 | 01:49 PM
cooper4x4
Default Transmission Leak
My wife's transmission has developed a leak. It is a 97 Accord DX automatic. When I was under the car changing the oil, the leak appeared to come from where the transmission mates with the engine. Any ideas on where to start looking to fix this? It is leaking at a rate of 10 large drops on the driveway each night. Thanks in advance. Let me know if you need anymore information.
Old Mar 12, 2008 | 05:38 PM
hondadude's Avatar
Default RE: Transmission Leak
musta been a miserable night laying out under that car counting drops. LOL
The only things that I think would cause a leak in the area you are describing, the shift shaft seal is behind the shift linkage/cable cover, or the Torque Convertor 'O' ring.
The lower torque convertor cover comes off pretty easy, maybe you could look for a trail of fluid.
Old Mar 13, 2008 | 03:40 PM
cooper4x4
ORIGINAL: hondadude
at least it was a warm night.
Do you have a diagram or pages from the FSM that would show me what you're talking about? I am used to working on my Tacoma which is a lot easier! Thanks.
Old Mar 13, 2008 | 05:22 PM
hondadude's Avatar
item#2 in this pic isa cover plate at the bottom of the TC housing.
Remember you saw red transfluid dripping there?
But look around closely at the sides of the trans to be sure the fluid isn't flowing downhill from somewhere else. TC 'O' ring leaks are not very common.
[IMG]local://upfiles/5417/ED7F474F67D141CCA48F0A95B9956A65.gif[/IMG]
Johnene
Aug 24, 2010 06:59 AM
v-tec23
Aug 14, 2010 08:43 AM
EBK142
Jul 20, 2009 09:10 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
jbruning
Jul 17, 2006 03:39 AM
