Transmission pushing out axle?
Old Apr 29, 2010 | 03:54 AM
warrior's Avatar
Default Transmission pushing out axle?
First im not a mechanic and I LOVE my 91' honda accord EX. Im try keep it short and simple sorry if i dont relay exacts just going on what i was told.
I started leaking transmission fluid by my axle and had the seal replaced. Now im being told my transmission is pushing my axle out and I have to replace the transmission which i did replace just 5 months ago. along with the axle were it is leaking from on the passenger side, and it is still leaking of coarse. I have had problems finding a good honest mechanic since moving any idea i can tell my most recent mechanic on what else might be the problem? should i just go to the dealership.
strugglin pizza driver doest want to sell honda
Old Apr 29, 2010 | 07:12 AM
It's pretty common that a replacement axle doesn't get pressed in hard enough. Then it comes out after awhile. Your mechanic needs to really pound the axle into the trans so it snaps decisively into place. He should try pulling it back out just to be sure it's snapped in.
Old Apr 29, 2010 | 08:42 AM
hondadude's Avatar
I cast my vote with JimBlake I'd guess the axle didn't seat fully into the differential.
The end of the inner CV joint stub has a clip ring on it that has to seat in a groove of the differential reciever.
The other thing could be the clip ring got lost somewhere ??
Old Apr 30, 2010 | 07:45 PM
warrior's Avatar
thx 4 ur time ill update the result
Old May 1, 2010 | 08:28 PM
kris_loehr's Avatar
I am voting clip problem, wrong axle(too short) or worn suspension component . When I did used cars at a dealership we once had a car which kept the pulling the axle out and ordered a replacement which did the same thing. I believe it was a Dodge and we found out they use two different axes for that year and were given the wrong one. I have found rebuilt aftermarket axles tend to not seat easily such as a clip problem or the splines not in great shape.
Old May 2, 2010 | 06:26 PM
warrior's Avatar
Default thanks 4 ur help
sold it and bought a cleaner new 92 accord i found
Old May 2, 2010 | 08:58 PM
LOL, that's one way to fix it!
tatltael
Feb 12, 2015 04:53 PM
Colondo
Apr 19, 2013 06:24 PM
razcob
Jan 6, 2008 01:58 PM
stefanb21487
Jul 26, 2007 10:17 AM
nixalot
Jan 25, 2007 02:02 PM
