Transmission Question
I pulled the P1738 code from my car, after some research I found that it's the code for the second clutch pressure switch. I'm on my second transmission on this car and shifting from 1st to 2nd is a little iffy. Is this a minor problem maybe even a diy or am I screwed.
it's very very simple.it's a switcheasily replaceable. it just unscrews.go to the dealer and tell them you need the 2nd clutch pressure switch on the transmission. unscrew the old one, screw in the new one. plug it in, clear the dtc, and ride away!
if you need pictures and stuff let me know. in the mean time, pick up that switch!
Thank you HondatechAV6, I will pick up that switch asap. Pictures would be greatly appreciated. I tried looking for it in my Hayne's manual, but all I found was a wiring diagram that was very vauge. I also searche online and couldn't find much. Once again thank you HondtechAV6!
MessAround
Aug 13, 2011 09:45 AM
genecrazy
Nov 8, 2006 02:29 PM
