Transmission Slip..?
Old Apr 20, 2007 | 04:53 PM
rloden
Default Transmission Slip..?
The other day I noticed that when I made a right hand turn, my stock 97 Accord SE (auto) downshifted like it is supposed to, then as I went into the turn and accelerated, the motor revved way up before the transmission began to engage. There was no sudden "clunk" or anything, just the high revving. Some people say that this normal, but I don't think so. Are there any adjustments that can be made? The car has 114K miles and has been very well maintained. I'm the original owner. Thanks.
Old Apr 20, 2007 | 09:34 PM
deserthonda's Avatar
Default RE: Transmission Slip..?
sounds like slippage to me......chk to make sure it has planty of fluid ... d lite on ??
Old Apr 21, 2007 | 07:44 AM
YeuEmMaiMai's Avatar
change fluid and add some lube guard for imports. My 94 did that until I change the fluid and once I did, problem solved. I would get it when going up a clover leaved entrance ramp..
Old Apr 23, 2007 | 11:23 PM
rloden
Thanks..I'll give that a shot. Use only Honda ATF correct? I'll look it up, but you don't happen to know the capacity do you..?
Old Apr 24, 2007 | 12:08 AM
19Accord97
Correct, only use Honda ATF.
Not to be a thread jacker, but what lube gaurd would you recommend? Is it safe, and how exactly does it work, is it safe, and when would I need it as I also have a 97 auto?
Mackie
Jul 15, 2011 07:40 AM
Rlyman1
Apr 14, 2010 06:41 PM
EL ROSTRO
Oct 5, 2009 10:54 PM
juanni
May 27, 2009 04:35 PM
wish234
May 6, 2009 10:47 AM
