Transmission Speed Sensor Problem
Old Oct 2, 2010 | 04:30 PM
GWARFREEQ's Avatar
Default Transmission Speed Sensor Problem
D.I.Y Request Form
Year and trim accord :1992 Accord EX
Your request for a DIY write up :
I purchased a used 1992 Honda Accord EX. The speedometer and tachometer do not work. I have tried a different instrument cluster, as the original had burnt spots on the PCB. I have replaced the VSS with a couple different units. I continue to get continuity all the way to the instrument cluster (no broken wires), but no 0-5v pulse. I tried removing the VSS, but leaving the shaft in the Power Steering Speed Sensor (PSSS). The shaft does not move with the engine idling or revving. I removed the PSSS. The shaft is in perfect condition and when I turn the gear by hand, the VSS shaft turns. The gear inside the transaxle that meshes with the PSSS, however does not move when the wheels are rotated. I am sure the next step is to pull the transaxle and visually inspect the inside for damage. Is there another idea I should check into first? If not, where can I find good schematics and/or instructions for dissassembly and reassembly of an automatic transmission?
Thanks in advance for your help.
-Nathan
Any additional notes that need to be added :
Old Oct 2, 2010 | 09:36 PM
I believe one of the online manuals links leads to a 91-92 Accord manual. This should have the transmission information you need.
Old Oct 6, 2010 | 12:35 AM
What's up there TexasHonda?
Good to see you in here more lately.
pondrun
Nov 8, 2021 09:40 AM
Afnan
Nov 19, 2013 05:52 PM
blueocean2719
Nov 6, 2012 03:34 PM
Accord12404
Dec 14, 2008 12:07 AM
Will5
Sep 13, 2006 07:22 PM
