tras problem in d4
Old May 25, 2013 | 03:22 PM
jdavids's Avatar
Default tras problem in d4
I had my trans fix because it wasnt engaging in first when i put my car in d4 but after rebuild once again is doing the same thing. If i put reverse or 2 it works really good. In 2 once going i put the car in d4 and it drives normally until i get to a stop.. :'( any ideas... Is there a solenoid in first gear.
Old May 26, 2013 | 08:08 AM
What year are we working on here?
Any stored codes?
Old May 27, 2013 | 07:36 AM
jdavids's Avatar
No codes so far... :'( my car is a 99 with a baxa trans on it..4cyl ulev vtec...tnx
Old May 27, 2013 | 10:05 AM
Silver6gen's Avatar
When did you get the rebuild? Sounds like a faulty or incomplete rebuild, I would return to the shop and ask them to warranty it. If they give you a hard time then turn up the heat on them.
Old May 28, 2013 | 07:51 AM
jdavids's Avatar
I did so and it seem to be a problem in the valve body...back to the shop... :-\
Enzo
May 7, 2012 07:11 AM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
