Trouble bleeding clutch 2001 Accord EX
Old May 25, 2012 | 09:24 AM
caffeine's Avatar
Default Trouble bleeding clutch 2001 Accord EX
Hey I'm just wondering if I can get some advice as to how to get my clutch bled properly. It's in a 2001 Accord EX with the 2.3L I4. Me and my friend were in the middle of bleeding the clutch a while ago; it was going well until all of a sudden the pedal lost pressure and just dropped to the floor. Since it appeared that there was air leaking in where the line connects to the slave cylinder, I installed a new X-ring in the slave cylinder. The leak appears to be fixed.
However, now the clutch does not appear to want to bleed. We even took a long length of hose and my friend sucked on it with the bleeder screw loose while I watched the master cylinder. We did this for a few minutes but the fluid level barely moved. There appeared to be air bubbles moving through the hose but I have no idea where are coming from. Anyone have some suggestions?
Old May 25, 2012 | 09:50 AM
crispin's Avatar
How I bleed mine as well as the brakes is take that long hose, connect it to the bleeder and loop the other end up into one of the holes in the underside of the hood (or your friend could just hold the end up in the air)
Loosen the bleeder screw, slowly pump the clutch. Make sure you watch the master so it does not run dry.
The air bubbles can only travel up the hose so it bleeds very well.
I have used this method many many times and has always worked great.
Old May 25, 2012 | 10:11 AM
The pressure-plate springs provide the normal spring tension to the clutch pedal, so when you're bleeding you don't get that. I like to loop some string around the pedal to pull it up when pumping.
However, use your foot to keep it under control when pulling the pedal up. It seems to suck air into the system if you let the pedal SNAP quickly upwards.
Old May 26, 2012 | 06:35 AM
....speed bleeder. They are selling bleeders with a check valve in them.
Old May 28, 2012 | 10:24 PM
I put Speed-Bleeders on a car & they were GREAT. A year later when I needed to bleed the brakes, they didn't work. I HATE SALTED ROADS & CORROSION!
So unless they start making Speed-Bleeders of stainless steel, I'll pass. It all depends on what part of the country you're in.
Did I mention I HATE RUST!!!
Old May 29, 2012 | 07:03 PM
I think your love of rust is we documented
This is the furthest north I've ever lived...and will ever live. Never saw a snow plow "in town" till I moved here....had to go to Maine because of work in my early 20's.....couldn't figure out what those funny winch bumpers on trucks were, then someone told me what they were people have their own snow plow on their trucks.....wow.
For brakes, I'm still with Newton...a little time, a drink or two...no rush. For a clutch, all in for the speed bleeder...just me.
fmcclure0311
Jan 8, 2022 04:35 PM
D_Thor
Jan 2, 2014 10:25 PM
Gadejfan
May 25, 2013 11:05 AM
JimBlake
DIY Answers.
Feb 19, 2013 10:09 PM
greasemitts
Oct 18, 2007 12:25 PM
