trying to fix my brake lights
Old Mar 26, 2011 | 06:13 PM
bjfowler6's Avatar
Default trying to fix my brake lights
Been working on my brake lights for a min now..So far I changed the bulbs, the fuse, brake light switch n yet it does not work....I was told it could be a bad ground thats causing them not to work is that true if so where can i find the ground wire for the brake lights
Old Mar 26, 2011 | 07:36 PM
It would help if you share w/ us the year/trim of your Accord? Place in your signature.
Suggest checking first that you have 12V on brake light connector pin in the trunk. You can also check for ground availability at same connector. If you don't have 12v, check for 12v to the brake light switch input (Wht-yel in 94 Accord), and check for 12V output when brake is pressed on output wire (grn/wht).
Old Mar 27, 2011 | 07:27 AM
bjfowler6's Avatar
ok n its a 1991 honda accord ex
Old Mar 27, 2011 | 08:33 AM
My response should be helpful. Let us know what you find.
rudeg
Dec 31, 2015 07:23 PM
csh217
Apr 30, 2013 09:03 PM
drive4fun
Aug 5, 2008 08:28 AM
aznpinoy217
Mar 30, 2008 09:17 PM
