turn signal too cold
Old Jan 18, 2007 | 09:58 PM
brayner's Avatar
Default turn signal too cold
my turn signals don't work when the car is cold. They slowly begin to work and work normally as the car warms up. Does something need cleaned or replaced? TIA
Old Jan 18, 2007 | 10:07 PM
hondadude's Avatar
Default RE: turn signal too cold
Yes there is a 'conductive' grease inside the turn signal switch, when it is cold and stiff, it lifts the spring loadedcontactor slide up a little as it goes over the contact bar, the only answer is to remove the switch and carefully take it apart, then wipe out the excess grease.
Or warm up the car till all the windows are cleared off before you drive.
One Legged Eagle
May 10, 2014 12:37 PM
bigdawg74
Nov 4, 2011 10:11 PM
NICK63
Nov 2, 2009 11:57 AM
farango
Feb 11, 2008 08:12 PM
Drpepper
Jun 7, 2007 12:34 PM
