turn signal too cold
Yes there is a 'conductive' grease inside the turn signal switch, when it is cold and stiff, it lifts the spring loadedcontactor slide up a little as it goes over the contact bar, the only answer is to remove the switch and carefully take it apart, then wipe out the excess grease.
Or warm up the car till all the windows are cleared off before you drive.
farango
Feb 11, 2008 08:12 PM
