undecided about repairing or replacing engine
Old Apr 12, 2016 | 12:07 AM
Brian Camilo's Avatar
Question undecided about repairing or replacing engine
I have a 92 accord lx which has given me a very hard time. When I bought the car, it was smoking from the tail pipe. Huge cloud of white smoke. I thought it was just a typical head gasket problem. I made a compression test and the numbers were 130 cyl #1... 135 #2...150 #3...150#4. I went ahead and ordered a gasket kit from ebay. replaced HG,valve seals etc.. Started the car and again, huge cloud of smoke. I didn't take the head to a machine shop because they wanted to charge me $85, so I went to my local pull-a-part and bought another head for $60. put everything back, started the car and again, the cloud of smoke... I honestly don't know what could be wrong.
The previews owner (an old man probably in his 80s) told me he had driven the car like this for a very long time, and never overheated. Is it possible he damaged the piston rings by doing this? I can't decide on whether replaced the engine or repair it. any suggestions
Old Apr 12, 2016 | 08:04 AM
rockhoundrob's Avatar
I would go with repairing it. You will need to rebore.
When you did the repair, did you rebore the top part of the piston shaft?
Old Apr 12, 2016 | 09:30 AM
shipo's Avatar
You might also consider just buying a used motor from a bone yard.
Old Apr 12, 2016 | 04:49 PM
Check car-part.com for used motors from junkyards nearby to get an idea of the cost. If the yard will do a compression or a leak-down test (better test IMO), replacing the motor would be cheaper than a rebuild.
Old Apr 12, 2016 | 08:14 PM
No I didn't rebore the top part. To be honest, I've never knew about this step.
I've been considering this option too. thanks for the response.
Thanks for the info! I would definitely look into that.
Old Apr 16, 2016 | 06:08 AM
Rilex's Avatar
my accord 1990 second car has similar problem of smoking for a long time now, now oil is coming out from the tailpipe, i was told i should to change the piston ring that will solve the problem of smoking. I think you should repair it than to get another engine replacement that will be expensive thanks
Old Apr 16, 2016 | 06:48 AM
shipo's Avatar
Here in the United States a used but good condition replacement engine is typically far less expensive compared to rebuilding an engine.
j__f__c__
May 2, 2010 09:37 AM
Antarctica
Oct 30, 2008 07:11 AM
Mr. Undecided
Apr 21, 2008 09:32 AM
breezd
Sep 13, 2007 03:57 PM
Scorpion
Jan 3, 2007 06:49 PM
