Uneven Parking Brake
Old May 4, 2013 | 06:03 PM
Deep Diver's Avatar
Default Uneven Parking Brake
Okay, in my 2003 Honda Accord the parking brake became very loose. I disassembled the console and noticed that the passenger side cable is substantially longer than the driver side.
I went underneath to see why this might be the case, but I can't seem to find any culprits. So right now, the parking brake only works on the driver side.
Any suggestions or causes for this. I realize that cables sometimes do stretch, but this amount of play seems excessive for a wire cable.
Old May 4, 2013 | 06:34 PM
Have rear brake pads been replaced recently?
Someone may have damaged the e-brake mechanical assy that actuates the caliper to set the pads on the rotor and provide parking brake.
Old May 4, 2013 | 06:54 PM
Deep Diver's Avatar
No, I looked at it and it seemed to look fine. The spring looked like it was in good condition and had no rust. When comparing it to the driver side I could not notice any substantial differences.
Old May 4, 2013 | 08:48 PM
Perhaps wire corroded and/or broke somewhere.
When you pull brake pedal does wire move the RR caliper ebrake mechanism?
Old May 7, 2013 | 09:36 PM
Might be the internal auto-adjust mechanism for the handbrake (inside the caliper). So as the pads wear down only one side of the handbrake is properly adjusting itself??
ryanw2427
Jul 5, 2015 07:54 PM
jenz
Jun 12, 2013 04:50 PM
Cash
Nov 15, 2011 02:40 PM
Planefreak
Mar 25, 2008 01:41 PM
russell
Sep 4, 2007 09:08 AM
